Hi
Can anyone explain to me how to get a normal Vray material from these settings on the attached screenclip as imported from Revit 2010?
Regards
hi, you only have to multiply your colorchannel by 255… red: 0.827x255=211 etc. like this you get the right rgb levels for your color…
I’m confused, how did you get the color values to display as float in max??
edit: I see, it’s in the pro materials only.
anyway, the most simple way would be copy/paste the color (right click on the color in the mat. editor), or use the color picker.
I stumbled on the copy/paste method as well. Thanks!
I’ve tried the scene converter on this file but it does nothing. The file was a 250MB FBX file from Revit 2010. I am now manually doing it… yay!
