Still need more work on site & surroundings but pleased with the house.
Any comments / criticism / suggestions to improve are welcome.
Cheers,
Steve.
The model it’s self is well built and rendered, the only thing I notice that’s out of place would be that roof-light frames are normally a dark matt finish (unless painted).
Since you asked; to make the image resonate more I would add in some dressing - patio furniture, kids garden toys, some pots with plants, garden ornaments etc. I would also dress the internal rooms a little bit so that you don’t just see dead space through the windows (Use neutral colours & furnishings with a splash of ‘lived in’ colour like magazines, books and coffee cups)
Thanks Gadget. Good spot. Completely forgot to add materials to the roof lights.
Agree too with the patio furniture.
Internals are the next on my list to model. Client just needed something quick for planning application. Hopefully I’ll get onto internals next week and update the results.
Thanks again :thumbup:
You could spend hours/days tweaking models like this with little things (…been there, done that…);
off set the valleys (and dormer haffits) 80mm and recess then 30mm, fill the channel with lead.
put a dead panel in the window frames that cover the first floor slab (One area it’s glass, another is missing a transom)
recess the lining boards over the windows to be just proud of the frames or in-line with the render (rather than proud of the render).
put some topography into the grass.
remove the puddles from under the porch canopy.
add rwp brackets & gutter brackets & gully traps
…nothing a ‘normal’ person would notice ![]()
