If I remember correctly, this issue is old already.
- Corona Proxy cloned using multi instance
- Expected result in IR
- Not renderer in final render
Win 10
C4D R20 (please check this issue with R20)
Latest version 7 + 8
You’re right, this does not seem to work in R20. I have tested in S22 and it works correctly there. I will log this internally.
Thanks,
Jan
We may want to add S22 to that I am removing my comment, my error was a workflow issue.
Also a few issues here too. ![]()
Hi there, this issue was partly fixed, but I think it is still not working correctly on R20.
I tested it with the latest build, RC 2.
IR is working as expected, all proxies are rendered. Final render does only render the first proxy in my SurfaceSpread cloner hierarchy. Surfacespread is set to multi instances. Render instances are working as expected.
Can you check this R20 issue again?
RC 3 isn’t out yet for C4D, but I will make a test.
Yeah, this issue is only in R20, it’s working fine in all other versions…
Sorry, I meant to say RC2 for you. RC3 is still being tested internally.
We just released RC3 a few minutes ago, are you able to test it with this build too and let us know?
I just tested it using RC3 and this issue is still there. Renders fine in IR, but in final render only first proxy is visible.
Thanks for checking!
Hi, thanks for testing and letting me know. Are you able to share a test scene for me and I will see if one of the guys has R20 to test it with?
Sure.
CoronaProxyR20Issue.zip (569 KB)
I think you’re exposed to ‘Multi-Instance’ issue.
Yep, you are right, it’s only happening when I set it to Multi Instances. Render Instances are working as expected.
