Proxy does not structure materials
Hi guys,
V-Ray 6 for SketchUp.
When exporting a SketchUp 3d tree file from Globe Plants, when converting into proxy, the multi material just paints simple random colors instead of linking the proper materials onto their 3d objects.
That is normal - expected proxy behavior as i know.. I suggest you to open the tree in sketchup, convert it to proxy, save the skp file.. When you want to use that tree, just drag-drop the skp file into your new file..
Hi @Israel3d ​,
Can you list the exact steps you take when creating the proxy?
Note that the .vrmesh file itself does not contain the material assignments but only the mesh data.
Konstantin
