Proxy keyframe viewport bug
Hi all,
There is an issue with (I believe after new update) keyframing proxies, the transformation values are indeed keyframed but the proxy position does not change in the viewport. In order to update it you gotta move it manually in any direction.
regards,
Karol
Maya 2023, V-Ray 5 Update 2
Switching between bounding box also updates the viewport without having to move it! Would be nice to get this fixed also in Maya 2023
Thanks @stezza ! oops..it is actually Maya 2023 :stuck_out_tongue: just edited it
Seems to be related to the New V-Ray Proxy node. I’ll investigate and write back.
Thanks for the report to both of you! Indeed this happens with Maya 2023 which is only supported with the latest V-Ray 5.20.02. I’ve logged it for developer investigation (internal bug-tracker id: VMAYA-11249).
