Proxy / linked model reload button?
Hi
Can we have an reload button for the proxies / linked models?
  • i have inserted a tree
  • opened the tree in an other instance of sketchup
  • modified the materials
  • saved the model
  • went back to the other sketchup and selected the tree model again under linked model
  • nothing changed
  • i then pressed the “linked model” button
  • selected an other model
  • opened the link again, and selected the tree from before
  • then changes was updated
It seems you can’t reload a model - well i can’t, if i don’t use this workaround.
But I might do it the wrong way?
Jorgensen
You can "unproxy a proxy by rightclicking > reload > select .skp. Make your changes and save as external proxy again.
Thanks @Vendel3D
I was not aware of that, but if i right click > select reload, and browse to the model, and select the model, all the proxies are gone.
That was not what i needed, but maybe I did it wrong, or I did not explain what I search for.
A simple reload button for the enscape proxies inserted in the current model, so I easily can update proxies i modify in an other instance of sketchup.
Jorgensen
Uhmm, yes, you have to select the proxy you want to reload first. Then rightclick.
I still don’t get it - I just wan’t an easy way to reload a enscape proxy.
An example -
SCENE
I have a chair linked in.
CHAIR
Then I open an other instance of sketchup.
Edit the material of the chair in the Encape material editor and save the file.
SCENE
Then I wan’t to reload the chair that has changes.
I open the Enscape Objects, link to the chair again - but nothing happens.
I then link to an other chair, wait for it to load, then relink to the edited chair - and i works.
WISH
I wish a simple reload button that forces Enscape to reload the model.
Jorgensen
As far as I know once you go to the original file and make changes, then save the proxies ini Enscape window update. Maybe you have the update icon turned off in Enscape?
Ah ok thanks @vjaramillo_cg - I’ll have to test that.
Jorgensen
Sorry vjaramillo - i don’t understand this part “then save the proxies ini Enscape window update”.
I don’t have a update icon only, a select folder icon.
Jorgensen
@Jorgensen_dk Enscape watches the filesystem for changes. If Enscape is notified that a linked skp file is changed, that file is automatically reloaded. If this does not work, please send feedback. Perhaps we can see in your log files what is going wrong.
Is the linked skp file by any change located on a network share?
Hi @Simon_Weinberger
The linked file is on my ssd external hd. I just tried to move the linked file to c:\ and then it works!
But that’s not the best solution.
If it’s not possible to automate this feature (does it cost resources to check for updates?) on external or network drives - a reload button would do fine.
Jorgensen
what I meant is, once you save the original file that you’re importing as a proxy, the change should update in the Enscape frame.
@Jorgensen_dk We’ll see what we can do. Thanks for reporting this shortcoming.
it seems not to update when the proxy is on an external ssd. not that i had time to test it deep, but i tried to move the file to c: and then it got updated.
Jorgensen
We save most of our design files on network servers. Currently I have a model saved on the network with proxy files saved onto my Local hardrive and as I make changes the proxy automatically updates as intended (awesome!). However when having those proxy files on the network servers they do not automatically update.
Any help is appreciated, thank you!
EDIT: Using Enscape 2.4 with Sketchup 2017 and 2018
