Proxy: optimization speed
Hi Ondra
when I switch Corona Proxy in “Full mesh”, the viewport speed is so slooow!
But, if I add an edit mesh and then Edit Poly on the top of CoronaProxy (in full mesh mode), the viewport speed returns, again, good.
Thanks =)
UP!!
And:
() when I try to select an export directory (with the Export script), the prosy is created in the wrong directory. Is it a script bug?
) It isn’t possible to change the Proxy WireColor This is a old bug. (Daily 17 January 2014)
yes, wrong directory is script bug.
Ok, good to know. But I’m not a scripter =( So, I cannot correct it
additional info: Multipainter bug with Corona Proxy. With VRayProxy, everithing is ok. - Corona for 3ds Max :: Issues - Chaos Forum
Done
