Proxy path problem
I’m having a problem with proxies when I load them in new scenes. I have the texture folder, but I’ve tried everything, and when I create a proxy and load the path, I lose the materials. Is there a solution?
thanks
Would also like to see where this goes. First, I’m assuming that you are starting with an empty proxy and not exporting an existing polygon object? There has been a consistent issue with proxy objects, where they can’t be re-linked without losing materials. I use the vray proxy export(0,0,0) and the vrml file lives in one absolute path for eternity. If you work with freelancers or are having to move vrmesh files around(relative/local) for example and have to re-link paths, this isn’t workable.
https://forums.chaos.com/forum/v-ray-for-cinema-4d/v-ray-for-cinema-4d-issues/1234518-when-changing-the-link-destination-of-a-vrmesh-file-materials-are-lost
i worked around the problem by placing all the proxy files in an empty scene with an absolute path. In this case, when I need a proxy, I can take it directly from there and copy it to other scenes. Another good thing is that if I were to move a scene with proxies connected, I’d certainly have the problem of reassigning them, but at least the materials remain anchored to the proxy object. In this case, I temporarily create a null object, drag the materials onto it, and then, once the path is reconnected, I reassign the materials. Unfortunately, I don’t see any other way. In fact, if you wanted a solution with a path and materials, there’s the .vrscene file
