Hi, i am using the latest version of vray.. I import two proxy to my scene, and i use compospray plugin to add them to my terrain.. It worked nice with default preview, but when i change them to bounding box and point, materyals are gone.. Is that a known issue?
Hi @kenancakir
Would it be alright if you share the project with us so we can investigate in detail? If this is fine, please send us an archived copy (Extensions > V-Ray > Pack Project) via email or a file-sharing service of your choice to support@chaosgroup.com (please reference this forum thread as well).
Hi, the original file is deleted.. I couldn’t make the same error happen.. I was preparing a video lesson about proxy, i have the error video saved and i can send it to you.. Obs studio (screen recorder) and interactive render might cause ram error but i have 16 gb ram.. I recorded four videos and the last lesson gave the error..
Hello, Kenan,
Do you happen to remember how the proxy files were imported in that file? Were they created on the spot or imported as part of another .skp file? We were so far unable to reproduce it. Any further info would be appreciated!
In any case, double-clicking on a proxy component and applying its corresponding Multi material should resolve the issue.
Kind regards,
Peter
Proxies are imported by using vray import proxy or vrscene button.. I tried to reproduce the scene but it worked properly with every step i remember.. I will save the file if it happens again and send it to you.. Thank you..
