Proxy renders differently
Hello Guys,
It happens to me sometimes that a collapsed mesh renders differently than proxy file. Could you look at this file?
Daniel
proxy bug.zip (13.1 MB)
Hi, I have found a problem and solution.
Problem seems to be objects with several shaders of which only some are assigned poly selection and rest are applied according to layering logic (shader on the right overrides one on the left).
So it seem like proxy object is not good at understanding stacking order of shaders.
Solution is to apply poly selection to all the shaders, when more than one are applied on one object.
Proxy bug fixed.zip (13.6 MB)
Another issue has emerged while using vertex map. Can proxy read vertex map to mix 2 Materials? Handle on top is mesh, handle bottom is corona proxy. They use same materials.
Vertex Map.zip (7.74 MB)
regarding #1: If I understand it correctly, you are collapsing a group of objects with some of them editable/non-editable and the issue occurs. If all of the children are made editable, the issue does not occur?
regarding #2: There are some vertex map issues that we are aware of and I have added this one to the list, thanks for reporting.
Jan
Hello Jan,
unfortunately proxies are revealing more bugs.
In this case #3 vase does not read bump map (seems to be general case of proxies for all shaders), project shader node and displacement on leaves (displacement is supported on proxies right?). I will upload it via private uploader
To Issue #1:see attachment, I am not sure what you mean by editable/non-editable. Simply put if a child object has several shaders applied on to it, all of them have to have poly selection applied. This is normally not necessarily since stacked shaders override shaders left of them in object window
Another difference in proxy and object are different reflections. you can see it in cork cap and bottle edges
Proxies should render same as objects they represent, otherwise I see little use of them
Hi Jan, could you also test those other issues I have posted here? These are major flaws in proxy system.
Hello Daniel,
I did and I’ve passed them on to the developers.
Proxies will require a major overhaul in the future, I cannot say when that will come.
Thanks,
Jan
Well, I hope it will be sooner than later, at the moment I cannot use them if they render differently to normal geometry. Proxy system is a big thing.
If I may add on to the subject of Proxies, is using Proxies similar to using C4D’s Instances? What’s the advantage to Corona Proxies?
https://help.c4d.corona-renderer.com/support/solutions/articles/12000023598-how-to-use-proxies-
Hi, the main advantage of corona proxies is that you can outsource geometry out from your file. This allows you to use it in several projects and also make the file size of your project smaller / loading, saving faster. However, since proxies do not work properly you should just use c4d instances for now (don´t forget to set them to render instances to save RAM).
C4D has a native proxy system of xRef. These can cause however very long saving times if used too many, Maxon will address this in some future updates.
Ah, yes. As I was reading your reply, I was thinking “Isn’t he talking about xRefs?” The idea of xRefs is great, but it’s broken. Any time I’ve tried to use it, the model ends up “breaking apart”, as in many of the part just move to another position and can’t be fixed or undone. Thanks for the info.
For completeness, I attached a stripped down example file for easy repro.
proxy_single.zip (59.8 KB)
Hi guys, displacement does not render on proxies in v6 but does in v7. Would it be a lot of work to make it work in V6 HF2 (which would make it HF3 I guess)? I don’t want to do a commercial project in rc v7
Daniel
both displacement and proxy changes have various dependencies which were introduced in V7 from the core and plugin sides. Stripping features to introduce a HF3 for displacement on proxies would probably take more work than to finish v7 release :smiley:
Thanks for understanding,
Jan
No problem jan, RC2 is good enough for me, I will install v7. I has also fixed projector shader so it is a good deal for now. Take care.
Just note that the Projector shader is still undergoing fixes, we are still aware of multiple bugs in there, but other issues unfortunately take priority before the release.
Thanks,
Jan
I found out that sometimes it can cause bad UVW projection in proxies, if set to uvw projection.
Yeah, that’s something we’ve identified as well.
Thanks,
Jan
