Proxy Sub Meshes Visibility // How can I do it?
Hi. I would like to know how to make Corona Proxies with the option of turning on/off the different meshes as some of the Proxies found in ChaosCosmos.
Attached is the screen of what I mean.
Thank you!
Yeah, I’d like to know this too…
This proxies are loaded as V-Ray proxies (which has hierarchy capabilities) here’s an example with a simple box and a teapot.
Check the path from Corona Cosmos imported objects, you’ll see that everything is vrmesh
Thank you RTStudio.
You’re right… with V-ray it is possible to do a single export, but not directly with Corona for now. I hope this feature could be added in the future.
