Hello, I have been searching this for a day, but I couldnt find it. The question is simple actually, we are trying to animate a model, but it is huge, it has like 100 different human models, some swimming some jumping whatever.. And to send it to renderfarm again and again (different cameras) we want the file as small as possible, so to make these animated objects corona proxy would help a lot, but when we turn it into proxy, it doesnt move, but there is a setting for animation. how do we use it? Out cameras roll around 750 frames each. so the longest lenght is 750
If you enable the “animated” option in the Corona Proxy during conversion of objects into proxies, then it should bake the whole animation into the proxy. Can you explain what exactly is going wrong?
Is it something about the conversion? (for example the animation does not seem to be baked into the proxies)
Or maybe is it something with displaying the loaded proxies? (the animation seems to be baked in during the conversion, but it cannot be played once you load a proxy file)
