Proxy with material
Hi all,
there is a way to save the coronaproxy with the same material of the geometry from witch it comes?
If not, everytimes i load a proxy i have to load also the original geometry to find the material to apply, right?.
thank you
I find that the most convenient way to keep materials on proxy, is to save them in max file. Then everytime you want to use that proxy, you just need to merge it from that max file and it comes with all materials pre-assigned.
Thank you romullus for answer,
yes it can be a way to semplify my workflow.
