Proxy
Hi. when right click in 3ds max viewport and open the toolbar. I had a Option That did the proxy operation directly. But now it’s gone.
I havenot export proxy
I also has this issue recently. Resetting the ENU folder seemed to fix it for me.
Instructions on how to do this are here: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Resetting-3ds-Max-3ds-Max-Design.html
Alternatively you can try to re-add them to the quad menu: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMax/files/GUID-3A803F43-6F87-40FB-97CA-33844078AF9A-htm.html
Go to customize > customize user interface > quads > category: Corona Renderer, you should see light converter and proxy exporter on the list, you can just drag it into the quad menu.
Let me know if this works for you.
Thanks,
Rowan
workaround
press X, type corona
Since Max’s UI redesign a few releases back I’ve noticed slow and odd behavior with quad menus, especially with 4k monitors. I try to rely on the default corona buttons in the toolbar now.
