I’ve just upgraded to 3.2, and Max 2016, and have a problem with proxys.
When I re-open a scene with proxys, the proxys don’t display. I can select them by name. Once I’ve selected one, I have to click on the “preview from file” button to display the proxys.
At the moment I wrote a little script to speed this up
objs = getCurrentSelection()
for obj in objs do
$.display = 1
but it’s still annoying and not right. I’ve searched and can’t see anyone else with this issue.
What was the V-Ray version of the original file? I tried creating a scene with old V-Ray and 3ds max version but everything worked fine with 3.2 and max 2016.
Probably the issue is related to the new proxy display options added in the latest service pack. We will double check that.
Meanwhile you can change the Display type for all proxy objects at ones using max script:
- Select all of the proxies in the scene
- in Max listener type: $.display = 0 for an example
Would it be possible to send us an example file, because the one we already have here doesn’t reproduce the issue. Also it was originally reported for V-Ray for 3DS Max 2016.
I just did the following test:
*) In Max 2015 / V-Ray 2.5 crated a scene with several proxy objects.
*) Then I opened the file in Max 2015 and 2016 / V-Ray 3.2 and everything was correct.
So it would be good to have a scene.
i had a scene with one max-xrefscene object. the proxies did not show up. even if i selected them they did not show. i had to “browse” the path for every proxyobject-meshfile (that was quite the right one and accessable) and had to “open” it again then it showed up the proxy.with every new loading it was the same…if i wanted to see i had to load again.
then i merged the xrefscene into the file, saved the file, loaded it again and all the proxys showed up.that was reproduceable.
We managed to reproduce the issue in our environment.
The bug has been added into our system and we are looking for a solution about it.
We will let you know when we have some updates on that regard.
Still suffering from this vexing problem here… & often its time consuming trying to select all the vray proxies to either individually sort out their display or to run that script.
Is there any update for this issue? I cannot submit my current project to the renderfarm and rendering locally is not an option. All proxies render as boxes when I first open the scene, or when I submit to the farm.
We are still working on it.
I am not sure if this is the same issue. The one that we are working on is only for the viewport preview. The problem that you have is with the rendering of the proxies, right?
Have you tried to use the script mentioned earlier, does it help when rendering on a local machine? Also do you get any errors in the log files after rendering your scenes?
