PSD composite - don't match final image
Hello
I have problem with reproducing rendered image based on render elements.
I use recipe found on various topic:
But there is a difference in images, here is a rendered image:
And composited:
And here is difference between two images:
I’ve tried both tga composite and exr composite, Photoshop and Autodesk Composite - always the same differences.
Does someone have some ideas?
Thanks in advance for answers.
If its not 32 bit comp then it wont match.
Also as far as I remember blendmtl wont comp correctly or I’m wrong, I think I’m wrong…
I’ve tried with 32 bit exr files (images are brighter) - the same problem occur.
Try using standard render elements non raw- u using any non vray materials blend etc etc?
Ok, I’ll try.
Only vray material is used.
Unfortunately still getting those errors but I’ve found a some workaround to what I am really up to.
Can u email me scene or post it here with assets?
dariusz1989@gmail.com
Here is a cleaned scene http://dl.dropbox.com/u/18219558/bugs/Render_Elements_debug.rar
Need hdri…
http://dl.dropbox.com/u/18219558/bugs/kitchen_probe.hdr
Yup, got same issue. If I remember the only way to fix is is to substracte and create new layer.
Not sure if the issue is due to photoshop being rubish at 32 bit or Vray. See if u can match them in nuke or ae.
What do you mean by “substracte and create new layer” ?
I tried the same thing in Autodesk Composite with the same result.
I mean do the comping as u do, duplicate them all>merge>substract from beauty > merge > and use that as ur fix layer on to of ur comp…
Ah, you mean to use difference to fix composition?
I know how to extract difference in photoshop but I have now clue what operation to use to achieve inverse effect - opposite of difference.
Trying right now
Reflection>Screen
Specular > Screen
Light > Screen
GI
Merge them all and call it Mergedlayers then
3ds max render - beauty Substract
Mergedlayers
data that are missing from ur comp.
Multiply or screen it on top of layers above to fix ur comp.
Here is my PSD file
I’ve tried that approach that you’ve described, with no positive result.
I am wandering if maybe there is some element missing or maybe I am adjusting reflection layer in wrong way - it appears most wrong.
I am using linear dodge instead of screen blending - It give me better results.
Never screen! Ever! That will never reproduce the beauty render. Only add or multiply can be used and you have to be working with all floating point buffers. Any buffers you multiply will have issues. The only way to correct them is to create your own raw buffers by dividing your gi by diffuse to create your own raw gi buffer for example.
linear dodge = add in photoshop.
I have other PSD file with imported exr files - the same result.
I’ll check tomorrow if all files have proper export settings.
Ife noticed in ur scene that ur beauty is 32 bit but ur layers are actually 16 bit. Make sure ur exr is correctly set up…
Ok, here is 32 bit version of PSD file, made of imported exr files.
