Basically, without buying PSD-manager from CEBAS, I would like it built in. In the g-buffer save settings, to be able to export it all to one psd file with layers for the appropriate g-buffer channels, would be a major timesaver.
maybe a work around untill then would be to make a photoshop action which loads all the files from a specific folder into a psd file and correctly sets up the layers.
photoshop allows scripting, (using javascript). Its pretty powerful, and you can do alot of stuff with it. Maybe what da_elf suggested action/scripts might be the simplest answer until chaos creates one. (if they do)
How exactly would you want photoshop to import the files?
One image each layer?
Any specific settings for the Individual layers?
Anything else?
