Hi it seems that psd manager gives out an empty psd file when using Vray frame buffer,
anyone know if ther is a way to make it work with vray frame buffer or do we have use the max buffer ?
yup, no Vray frame buffer if using PSD Manager. I found this also. But I only use PSD Manager to generate masks, so it doesnt effect the base render.
On a side note, does anyone know when or if the 2010 Max version has been released yet? It’s kind of holding up my upgrade push at the moment.
I got this from Cebas on April 20:
We are working right now on the re-compiles. IN a few weeks we’ll offer the recompile.
edwin
From the psd-manager manual:
You should not enable the V-Ray Framebuffer when using psd-manager with V-Ray 1.5. This ensures that psd-manager can access the rendered image, render elements and the multi-layered G-Buffer.The VRay-Framebuffer could be output by psd-manager, if special support for the VRay-Frabebuffer access were integrated. However, all the nice G-Buffer output options would still not be working, because the G-Buffer is only available in the 3ds max-Framebuffer. Both Framebuffer types are usually not available at the same time.
Poll: Would you still consider it usefull to be able to output the VRay render elements in Vray-Framebuffer mode even if it means the G-Buffer Output is not working in this case?
The psd-manager 3ds max 2010 version will be available in May (probably next week).
Daniel Schmidt - Your psd-manager Developer
Yes, it would be useful still.
i second that
psd-manager 2.1 is now available and supports 3ds Max 2010 and 3ds Max Design 2010.
Press Release with all details: http://www.cebas.com/news/read.php?UD=10-7888-33-788&NID=328
Best Regards,
Daniel Schmidt - psd-manager Developer
great thanks
