PSD2Mat is a production proven connection between Adobe PhotoShop® and Autodesk 3D Studio MAX®. This maxscript converts layered PSD Files into a Scanline or VRay-Material. Named layers are converted to bitmapfiles and assigned to their respective material slots.
Features:
Autodetection of map names in layered PSD files.
Versioning
Configurable with ‘textfiles’
Photoshop Template Helpers
Georg Duemlein aka RDG developed this tool.
Anselm v. Seher-Thoß aka PsychoSilence was the advisor in this project.
Last but not least we’d like to thank Keith Boshoff (Wahooney) whose PSD2Material was the cornerstone for developing this tool.
I actually had the same workflow idea (Assigning PSD files to materials and maps) for the GhostPainter - PSD Layers Utility. But GhostPainter doesn’t offer to convert the PSD into another file format before the assignment (but it supports assigning to any material type and composite maps).
What I didn’t understand was the following sentence on the PSD2Mat website > We could use the complete PSD as a bitmap in all available maps slots. But this results in a huge memory footprint especially if you are using many PSD Files on objects in numbers.that assigning a PSD directly in 3ds max would require more memory then assigning a converted file. This doesn’t make sense to me, because not the complete file is kept in memory but only the image data itself.
Well, this is a statement made by my Advisor Anselm, I didn’t double check it. I could imagine that it is maybe *faster* if the maps are presplit than having the renderer loading huge PSDfiles and extracting the wanted map date, especially if you don’t use all of the available layers …
Yeah I heard of Ghostpainter. In my current state of freelancing it is more efficient to spend some time in write such a tool than spending money on just another commercial plugin.
For the additional features and supported maps:
PSD2Mat is a strict pipeline tool. It cannot and won’t offer you the freedom a plugin written for the masses.
This approach has several benefits:
The time needed for training your artist is reasonable less as there less features.
You can adapt it to your pipeline and just offer the features your pipeline requires: no need to double check this illiterate shad0r gladiat0r who won’t get that there are no composite or IOR maps in your pipeline :?
You can set the way the layers are mapped: “rudi”-> “Diffuse” or even “bump” → “diffuse” + “specular” …
And it offers a basic backup system
I would like to ask if there is a way to save the rendered image as PSD and then when opening in Photoshop to have different layers for the different materials? It would be great also!
I edited my last post - as it was very weird - am sorry for that.
cebas PSDmanager(?) splits rendered images into render elements for photoshop. I sure has material id support.
My Mat2PSD handles ‘just’ materials and splits maps into photoshop layers.
I just started coding today and there is no download available yet.
But I try to get it finished
