Publish Enscape asset names
Status: planned
sketchup is not the best at organisation. we are using a script to export the names of all the objects to then filter out the enscape assets, which we then put back through another script to place these assets on a layer, e.g treets, other vegetation, people, etc.
publishing the names of all the enscape objects prior would aid us immensely as we dont have to build the model to use an object to be able to then extract its name.
it would speed this proicess up immensley.
Submitted on AHA Ideas (ENSCAPE-I-1514).
Thank you for sharing this! Just to clarify, is the main challenge you’re trying to solve the correct layer assignment for Enscape assets? If so, would a dedicated feature that allows direct organization of Enscape assets into layers (like trees, vegetation, people, etc.) be a helpful solution? This could streamline the process without requiring manual extraction of asset names.
Submitted on AHA Ideas.
Yes, that would resolve the issue. Having each type of asset on its own layer is our end goal. Being able to switch on/off the types of assets makes creating specific types of render output much simpler.
Thank you for distilling this idea into a better suggestion.
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
