Purge Unused?
Is there something wrong with purge unused in the Sketchup plugin? It doesn’t do anything for me. For instance, if I create a new Sketchup file, all I’ve got is good 'ole Marc standing there and a bunch of materials like Marc_Hair, Marc_Pants, etc… If I select Marc, delete him, and then click the Purge Unused button in the V-Ray Asset Editor, it doesn’t remove any of the assets… even though clearly, none of those materials are being used in the file anymore. Am I doing this wrong, or does it not work?
Kindly note that, in this case, you would have to delete Marc from the Components tray as well. Even though the geometry is non-existent in the scene, it is still usable as a component and the reason the Purge unused does not delete any related assets
Ahhh, makes much more sense. Thank you for the tip!
