Qt platform error
recently i’m having this issue when i try to import, insert or open an obj or fbx. It happens since the last Vray update.
I’ve talked with McNeel and we’ve notice it’s something related to Vray, if i disable Vray plugin there’s no problem importing obj or fbx.
I’ve also tried uninstalling Vray and making a clean install but it always appears
Any idea?
If there is a crash after the message appears, there should be also a dump file(with the extension .dmp) generated in the desktop.
Can you please send the .dmp file here: https://support.chaos.com/hc/en-us/requests/new so our devs can investigate?
The file should be quite huge so don’t worry if it ends up being over a gig. The uploading platform in the link above should be more than capable to transfer it.
If the program is not crashing you can still force a .dmp file to be generated through the Task Manager. Right-click on the process and select Generate dump file.
Done!
Thanks!!
Thank you for the provided file!
Please update Chitubox to version 1.9.1.
Chitubox is using a global handler with the same version of Qt as V-Ray is using and that is why this is occurring.
The issue described here is the same Qt crash on export - V-Ray for Rhino :: Issues - Chaos Forum
Let me know if the update resolves the issue.
You saved me!
i’ve uninstalled and cleaned Chitubox (because i’m on a dealine) and everything works perfectly again!! i’l try version 1.9.1 a.s.a.p. but at least i know the problem source
thanks again!
