Quad Menu reappears and Chaos Scatter Dissapear on Max 2023 with Corona 9
Hi there, recently I created a new Quad menu and I have assigned the Corona Tools in a different place from original when installed, the problem is that every time that I open 3ds Max these tools reappear and not just Corona, some scripts from Phoenix too, its not really annoying but I prefer to have them where i put them.
I have tried finding them on the mnux file from Custom user interface, but theres nothing there. Hope u can help me with this.
Im working with 3ds Max 2023.2.3 with Corona 9, theres also an issue with Chaos Scatter, after installing this version this plugin dissapears.
unfortunately, I was not able to reproduce it - all works as expected.
I would suggest you save the button “preset” (go to Advance Option and click Save As Startup) and then check again.
Hi Nazar
Thank u so much for answering, i didnt received any notification about this, what do u mean about “save the button preset”? ive tried “Save as Startup”, but the issue remains, ive already reset max as defaults even in a new machine and quad menus still appears there, like i said, Vray,Corona,Phoenix scripts are listed :frowning:
Someone in Autodesk give a hint about Vray Quads and that worked out but only with Vray, Corona Scripts still appear deleting them as Adminitrator, do u have any kind of script that i can take a look?
