Hi
something that keeps bothering me is that no matter what, some of the Corona quad scripts always reappear, even in 3ds Max 2025 where menu editor has been remade and now every other plugin script can be deleted but not Corona, in previous versions, even Chaos Phoenix and some Vray scripts couldnt be deleted, I always create a custom menu and I have Corona in another quad, but “open corona Converter” and “open corona proxy exporter” always reappear
I created a small video from my side where this error clearly shows up. Check this out.
Note: it happens only with Corona installed in 3ds max and it happens exactly with “transform quad menu (right-bottom quad)” Other quad menus seemed to be ok when changing, adding separators, deleting etc.
Also, it somehow envolves these two quad menus “Open Corona Converter and Open Corona Proxy Exporter”
Not only Corona 12 but earlier releases as well, that a long time bug I presume.
Is there any news about solving this issue?
It breaks every script or plugin in the quad menu, doesn’t remember them, and shows error logs every time (screenshot attached).
Do you perhaps have a temporary tip or workaround to avoid this?
For example, is there a way to remove these “Open Corona Converter” and “Open Corona Proxy Exporter” entries to prevent them from causing issues with other plugins and scripts?
