idtools
February 28, 2007, 12:53pm
1
Hi all
We encounter problems using the render elements (when we can extract them ) .
We use the channels in photoshop compositing and for now, it’s not reliable.
Is there something we can do to increase the quality of them ?
Here is the render, looking fine for us :
But, the DiffuseChannel :
Here, our render parameters :
Thanks for your help
Arno
vlado
February 28, 2007, 1:09pm
2
Arno, did you render the channels separately from the main image?
sv
February 28, 2007, 1:13pm
3
you could try ticking ‘object outline’ and ‘nrm thresh’ and see if that helps…
idtools
February 28, 2007, 1:54pm
4
vlado> We render all in the frame buffer.
sv> That was the clue… It works very much better.
New users… still discovering.
Mucho thanks for your help.
Arno
idtools
February 28, 2007, 3:20pm
5
It seems to work well on RGB Channels, but not for the integer channels as RenderID or 3dVector as Normals.
Is there a possibility to increase the quality of these ?
Thanks for your help.
Arno
Integer Channels are not antialiased at all. You might wanna try using wirecolor instead.
Regards,
Thorsten
Use Image sampler -Fixed- and the elements dont’s crash.
