There can’t be too many classic Porsches! Very lovely set. The only thing i would complain about, is the water in top down shot, it looks very strange. Other than that, looks about perfect!
Thanks a lot for your words! You are right about the water. At the beginning I thought I should emphasize the reflection a bit to make the reflected plane trail more apparent, so I raised the ior (bad call ). I will probably go back on that one and redo it.
