Quest 3 VR Issue
So I just started incorporating VR into my Revit/Enscape projects and I’m getting a little flickering with the right eye only when looking around. I’m doing it on a laptop with the specs of: 12th Gen i9-1295HX 2.30 GHz, 64 GB ram, windows 10 pro, Nvidia GeForce RTX 3080 Ti… has anyone else had this and is it most likely spec related or is there something I can do to smooth it out?
I think you should check VR Settings. In Enscape, adjust the VR settings. Lowering the quality or resolution may help reduce flickering.
