The soften parameter is used to control the abrupt cut-off of Blinn and Ward hilights when the surface turns away from the light with low glossiness values. I believe there is a similar option in the Standard material.
For the point mode, the entire proxy is displayed as a single point, to ease the viewports a little bit in case you have many of these.
