Question: Render Particle
Hi I was trying to play with Vray and I was wondering which V-Ray Note is similar to Redshift Point Attribute?
Please check 01:32 here: Houdini In Five Minutes 14: Rendering Grains In Redshift
vrayUser color vrayUser float and vrayUser int. The devs have fixed so it should pick up correct in all the situation i have tested. From curves to geo :slight_smile:
That is surprising. Are those grains ? Could you share a hip file, or at least a screenshot of the shading network ? Could you try specifying the attribute name under the Renderer ROP → Objects → Forced Attributes list - it should not be necessary if you’re using a User Color in the shading network but regardless, it might be the case the attribute is not being exported.
Best regards!
edit: I just realized you’ve shared the video. I’ll check in a bit. Thank you!
Yeah I used the vrayuser float and it worked! Thanks
