Quick Question - Hidden objects - slow down renders ?
Hey guys,
A very quick one this.
Do you know if lots of hidden geometry can slow down the rendering, or have an impact on memory ?
Nothing bad is happening but I was just curious.
:slight_smile:
it would be pretty easy to test your theory.
Yes theoretically but not for me at the moment - computer locked down in 2 hour render :frowning:
Me, too :roll_eyes:
Depends… Have u unticked option to not render hiden objects?
Yeah I’m pretty sure in my presets I have it set to that, along with the hidden lights.
Will know a bit later on though.
if you simply delete the hidden geometry/lights and try rendering, does anything change? if not, then its probably something else. Check your dynamic memory limit (first thing to check)
Hi Dmitry,
As I mentioned it wasn’t a case of noticing any problems, just a hypothetical question that I thought perhaps someone would know.
Obviously I’ll try a test when I can.
Hey guys.. I just wanted to share that with a new build of V-Ray its always best to NOT use any pre-existing render presets. I ran into issues in production using old presets with new builds.
Cheers for the heads up, I tend to make the presets per-thing I’m messing around with.
Good to know anyway :slight_smile:
What issues?
Is this something we can fix?
/Teodor
