I always use the VFB and often render elements as well. I don’t always like to have the ‘save’ option active while rendering namely because I tend to screw up and forget to change it and overwrite files too much.
So - when I render to the VFB and all looks good then I have to manually save out each element one at a time. It would be really helpful to just be able to click ‘save all’ and have it save all elements just like the split render elements option does.
actually, I mid-read the request, although this would be useful, but what would be great would be to write a multi-channel exr as well.
Although am I right in thinking this isn’t possible currently as the vrayfb uses the max save function when saving as described above - thus multi-channel exr isn’t supported by max?
