Hi
Just got to test the new “scatter” function in 3.2 and have a few suggestions:)
The density scale could be even more dense so that you can use it to scatter grass.
It would be great if the scattered objects would come out as a group so you don´t have to select every object (in case you want to delete everything or maybe just hide it)
Thank you @silverwingsltd , I will gladly forward your inquiries as feature requests to our product management team. We appreciate the Feedback so far! If you can think of anything else, let us know anytime of course.
I would like to bring this thread back to light. I am attempting to do scattered megascans grass assets and using the Enscape scatter the density is not enough. Instead I will have to write a dynamo scipt that has a dense scatter to get the desired results.
Thanks for the input - Please kindly forward it to product management as well for further discussion by using the “Submit Idea” button in the corresponding provided Voting Portal here:
https://portal.productboard.com/enscape3d/7-enscape-portal/tabs/17-under-consideration
We appreciate the feedback, now and in the future if you’d like to request more.
