animated lights & moving objects, do not want flickering → only solution is direct computation, isn’t it?
thanx
thanx
IRmap calc. for each frame I believe.
agreed
Re: quick urgent question…
Yea you either have to use Direct Comp or calc a new IRmap for each frame.
-dave
use lightdomes without GI.
thanks you guys…
i tried to use an irr map for every frame, but i got heavy flickering and
the light distribution was not so nice… did not really play around too long though
well, did not try the dome → that reminds too much of the old days ![]()
i managed to get an average of 4 minutes per frame with direct computation, 15 samples, and fixed AA set to 4 and no secondary bounces
(image had more grain and took a bit longer)…
it’s was for a very quick job but compared to my standard irr map setting without:
any flickering,
precise light only by self illuminated cubes,
no “light artifacts”,
a bit of a grain, but i got used to that ![]()
and about double render time…
hope the 900 frames are finished tomorrow morning ![]()
