I just found out that you can quickly render out a VRayZDepth and some other render elements without having to re-render the whole scene, which can be useful if you forgot to setup your render elements after you’ve already sent out the job. This can be done by using a VRaySphereFade Atmospheric.
First go to the create panel > Helpers > Atmospheric Apparatus > and create a “SphereGizmo” and put it somewhere in your 3D scene but make sure nothing is inside or touching the sphere.
Next go to the Environment and Effects menu and in the Atmosphere fly out, add a VRaySphereFade.
In the “VRaySphereFade parameters” rollout Pick the SphereGizmo as the Gizmo.
What this ends up doing is that vray will only render things in the sphereGizmo but as a nice side-effect a lot of the render elements will render out completely.
If you guys know of a button or a simpler way of quickly rendering out elements please let me know, but if there isn’t I hope this helps someone.
A lot of the time I’ll put on a black override material, turn off lights, shadows and gi and then do a render to get my matte passes. In this case vray might have slightly dodgy looking edges due to it’s early termination, so try using fixed aa at 2 or 3.
I dont understand this workflow, since you say “make sure nothing is inside or touching the sphere.” and then “vray will only render things in the sphereGizmo”…?¿ anyway, right now my render elements are rendered with the exact area of the RGB, thus the area included inside the SphereGizmo, maybe this was “fixed” in recent builds?¿
