Quickly output to layered sRGB?
Hi!
Normally its fine to output my renders with multi-passes to 32bit linear. But frequently when I’m doing look-dev & testing work, it would be easier to output directly to 8bit sRGB (or indeed 16bit aRGB) psd’s.
Is it possible to do this from the pictureviewer?
Whenever i try, it defaults to linear colourspace which is not good for what I want (the multi-pass layers are just simple object buffer masks).
