I’m looking for a very easy program that makes:
- quicktime panoramic movie from a spherical camera render with fov set to 360°
- quicktime movie of an object so that you can rotate around the object (movie created from for example 36 renders by moving around the object)
you can change my script to output a cubic enviroment:
change
(matchpattern (renderers.current as string) pattern:“vray*”)
to
(matchpattern (renderers.current as string) pattern:“xyz*”)
the script will then use the code for the scanline renderer which outputs to six files and stitch it then together. The six files will saved to a folder and can be dropped into gocubic, which then generates the mov file.
you can splitt the spherical file also with ptstitcher.
btw, i’m working on a simple script which let you output a applet based object panorama.. make a circleshape around an object , pick it and voila… at least kind of.
i use a simple (and i think free) plugin that comes with a redicilously small software called “gocubic”. look it up, and if you don’t find it in the web mail me at noam_farhi@yahoo.com and i’ll send it to you. it’s really small and simple.
regards
I’m using vr objectworx too, works ok, but it’s painly slow to load the images, anyone with the same problem? Also if you put 36 pics together as a qtvr then when you play the qtvr movie it starts with frame 18, anyone have that problem too?
howto:
Draw a circleshape (will be the camerapath) around the object, start script, pick circle, pick target, give filename(jpg or gif) and let the script render the images…
The two thin lines stands for the “6” and if you look carefully you can see on every barcode on the world that there are two thin lines on the left, in the middle and on the right… 666 ..and this means the barcode is the mark of the beast! hui! *g*
