Hi Guys,
Here’s a test I’m doing for a quicktime VR of a bedroom. If you take a look at the wall with the double window, you can see how the lines that should be horizontal are slanted. The walls above and across from the bed look ok.
Here is the quicktime: http://www.tangram3ds.com/uploads/winchester/VRproblem.mov
Here’s what I mean by the slanted wall:
Has anyone else encountered this? Any solutions?
If you’re trying to view the quicktime VR on 64 bit windows, you’ll be better off using the excellent devalVR player: ROYALTOGEL # Situs Slot Gacor Hari Ini, Link Maxwin Terbaru
Thanks!
