I’m learning how to use 3ds max to create scenarios and recently i started using Quixel Bridge to help compose the scenarios. My problem is when I’m going to render the scene. For some reason, the assets appear completely deformed in the render.
In 3DS max, assets appear normally, but when I render it gets weird.
I don’t know how to solve it. I’m newbie in this world.
I think it’s incorrect displacement strength. AFAIK every asset from Quixel comes with accompanying json file which among other things has height range information written in it. Find it and use that info to set your displacement strength to correct value. Also make sure to use both, min and max level in displacement. For example, if you’ll find that certain asset has 10 cm height range, its displacement strength min level be set to -5 cm and max level to 5 cm.
Yes, definitely the displacement in the imported material has incorrect height here. Last time I used Quixel I remember having to fix this manually, I am not sure if there is some other way. Perhaps contacting Quixel support would be the best idea?
There should be a Corona Displacement modifier that you can adjust to get the correct displacement height. In my experience, it is always too high, and I’m not sure what is the correct value besides just using my eye.
Also, I’m not sure if this is an issue for anyone else, but the default bump value is set to 99 on Quixel materials…I usually adjust that back down to 1.
I’ve also noticed that the format of displacement maps from Quixel isn’t great because they don’t use full values from white to black, so I often plug them into a gradient ramp to adjust the levels so I can get the full range. This gives me much better control of the displacement.
Another issue I have, and I’m just throwing this out there to see if anyone else has any input, is that I often find Quixel metal material to be wildly inaccurate when compared to their shader ball example.
Eh, I don’t know why I over complicated things so much in my previous post. Yeah, they are still keeping the Height parameters in the JSon files - at least from what I can tell.
This info might be golden for me so I’m going to give it a shot and see how it works. I was searching for some sort of “real world” / consistent scale numbers and with the height number I think I’m getting just that.
Thank you so much for taking the time to share this stuff!
It really exists a problem with the displacement from quixel assets. When I removed it from material configurations, it appeared “normally” on the render.
Romullus, then I did what you’ve told me about going on the .json file and see the height value. I’ve divided by 2 and put the negative and positive value; it looked really consistent. Although I cant have a parameter of how the texture really is. I hope that quixel fix this error as soon as possible.
@Dkha, it looks like your object is getting displaced, but not subdivided. I have no idea why it’s happening, because subdivision should happen automatically. It might be some simple mistake in your material, or scene setup, but it’s hard to tell without seeing the scene. I suggest you to upload the problematic scene to Corona uploader, so someone from the support team could take a look at it and find what’s going on. Chaos
Update:
Quixel team has just provided a Corona displacement fix, which most likely will be built-in into the new versions of Bridge.
To use it, please download the attached file and unpack it. There is a readme file inside explaining how to apply the fix.
From my tests, it seems that the too strong displacement issue is completely resolved now. Please test it and let me know how it works for you. corona-disp-fix.zip (648 KB)
Hello there. First of all, I’m sorry for my english.
I went back to using Corona Renderer again, But the displacement problems have also returned. I downloaded the folder and put it in its place, but nothing has changed.
I end up editing displacement maps from Quixel so that they utilize the entire range between pure black and pure white. I then adjust the displacement distance myself until it looks the way I want it. The default displacement values are too large for me to even make sense of them.
The images I’ve attached are looking at the displacement map for a stucco texture from Quixel. The default range of values isn’t great as you can see the spike in the middle of the histogram. I simply adjust the levels so that the entire range from black to white is used. I find this gives me much better control of the displacement of the texture.
I’ve uploaded two additional images showing the results with the default Quixel displacement and my method. As you can see, they are nearly identical, however, I like having a bit more control on how much the displacement is occuring. The default Quixel material had a displacement of -1 54/64" to 1 54/64". However, that’s not actually how much the texture is being displaced…it’s actually only being displaced about a quarter of that amount. Using my method, I set the displacement to -40/64" to 40/64", and I know that the absolute lowest point of the displacement is -40/64" and highest is 40/64".
I can’t find any issues here either, I’ve investigated the export process of that specific asset “Canyon Sandstone Rock”, the asset is exported to 3ds max/Corona with 2.5cm displacement value. Although it might look a bit excessive when compared to the actual asset within the Quixel bridge, please note that the previewer of the bridge doesn’t seem to have any displacement whatsoever (only albedo, normal, ao/cavity, roughness).
Regardless, under similar lighting conditions, the result is pretty much the same, do note that Quixel for some reason exports all assets within 3ds max with 99 bump, usually this creates some unwanted artefacts on the model, I would suggest you lower it to 1.0-2.0. (please see attached images)
About the normal 99 bump, I’ve already corrected it before reaching out. This problem I’ve been aware for quite some time, but in relation to displacement the problem persists, regardless of the 3D model or light configuration. I tried to reproduce the same light at the same position of the image you sent me and nothing changed.
Even though I changed the displacement to 2.5cm, the model is still “strange”
I’m attaching some images as an example with your configurations.
I use the Corona Version: 6 (Hotfix 1) and the latest version of Bridge (2020.4.3) with MSLiveLink 5.0 (The same as the folder you posted here).
I don’t know how your model supposed to look, but if you think that displacement is wrong, then check if you load height map with correct gamma - it should be gamma - 1.0 The same goes for normal and roughness maps. Albedo map should be loaded with gamma - 2.2 (or automatic).
I changed the gamma, but it didn’t make a difference. In addition, it also changed the displacement values to 0.3 cm and 2.5 cm and remained the same thing.
I attached a render of how it should be, it was made by Corona support.
