R23 Not Installing...
Hi Support,
I got my new C4D R23 today and trying to install Corona. It runs the installer but it is not in C4D R23. I have R20 with Corona installed and works ok. Probably something really simple. I did try and select the R23 plugin folder for path but this does not work either. Thanks, John :slight_smile:
Did you use version 6 HOTFIX 1?
Earlier versions are not R23 ready.
No, V7. The changelog says it is R23 compatible but when it installs it says it is V20 installing.
First try using the “Custom” option and ensure R23 is selected there (sometimes it isn’t by default). If that doesn’t make a difference, let us know!
Hi Support Team,
Yep, custom install worked perfect. Thanks! :slight_smile:
Most welcome!
