RailClone
Hi guys, I’m trying to use for the first time Railclone but I don’t understand what or how should I do to work this thing out for creating roof.
I watched those two tutorials:
  1. https://youtu.be/hjDG-srH57E
  2. https://youtu.be/ZzkQyz9Lpm8
    First is for instalation and some tips how to use it (the instalation worked perfectly but I couldn’t place the seats like the guy did), and the second is for roofing with a script but, again, didn’t work. I runned that script, and then select holding shift al the poligons but the option “Add Boundary Spline” was still frozen and could apply it like in tutorial.
    I don’t know if I’m missing a step or maybe using a roof from archicad as a base isn’t right and then what sould I use? ooor just doesn’t work. Please help me guys!
I think you could expect to get more qualified help if your questions would be posted on Itoo forum. They have very good support, so why wouldn’t you want to contact them.
you are right, thank you!
this is much easier tool for making roofs
thank you a lot bro, you saved my life
Itoo script requires poly and not mesh.
i tried with a plane and a piramid from max, and also didn’t work
Non of them are polys too. Select your object, right click, select “convert” and choose “editable poly”.
Hope it helps
it worked to add boundary splines, but i don t have time now to continue to add roof tiles, i ll try that later, thank you a lot!
