new render with Corona for photostocks
I did some tests with daily build 2015-09-14 and that’s the question:
is it possible to do /render to selection/ working good with /resume from file/ option without artifacts on edge of selected render objects, when disabled /clear VFB inbetween
renders/ in frame buffer, and without cleaning VFB, for some kind of compositing directly in VFB. Something similar like in Vray Render/
For example: if i want to change texture and color of one or several trees on the foreground without clear VFB/ on the finished picture in high resolution, or /load from file/ and render
only this trees with /render to selection/, same in Vray/
Now, if i do this, i get artifacts on edge of objects
Evening version
Witch with owl Corona render/
denisgo22, can you stop this spamming, please? You’ve registered this as a bug and as a feature request already. I’m pretty sure it will be adressed when time will come. There’s no need to repeat it over and over again.
perfectly!!!
though there is some reaction on this/
