i had the same problem. after hours of tinkering with the scene it appears the culprit in my case was the interactive lightmix. after removing all light select elements ram use returned to normal.
OK this is good to know, I’m rapidly running out of RAM on a scene I’m working on at the moment so I’ll have to make sure to disable the lightmix feature for the high res version.
