Hello
I received an error message, out of memory, but the strange thing is that the message shows that I have less memory than the one I actually have, which is 128. I asked you a while ago regarding the same problem, and one of the members told me that it could be due to orthographic and displacement conflicted, but this time it appears in the final renderer, not on the interactive render
Thank you
Are you able to send the scene over to us so we can take a look?
I would also like to know which versions of Corona and 3ds Max you are using?
Thanks,
Rowan
Hi
I sent this file to you before, and I did not get any solution to the problem, and your response was that you will fix this problem in the next version, after waiting for more than a month. I solved the other problems, but this time the problem has changed as I explained previously. You can follow the topic from here
https://coronarenderer.freshdesk.com/support/tickets/204811
Thank you
