Ranch / Maya / Vray
Hi all,
If some of you have some experience with Maya/Vray projects rendered at Ranchcomputing, it would be nice if you could share some infos.
We will be sending a quite big project soon and I’m especially worried for the IES profiles that we are using. Do you organise them specially, force the path to somewhere ?
Any other hints to avoid beginner mistakes ?
best regards,
Olivier
Dont have any info regarding Ranchcomputing but we did have problems with having 2 different IES lights in the scene. Every time we opened the scene all the lights would take on just one of the IES lights ignoring the fact there were 2 types so had to update every time.
Is it possible to get me that scene so that we can debug it?
I’ve tried to reproduce the problem, but I couldn’t.
I’ve tried a simple scene with two IES lights (2 profiles) both in-maya rendering and maya batch.
Both worked fine, so I’m waiting for a scene, where it breaks to further debug the problem.
/Teodor
I will get the scene for you later tonight (UK time). It would be a very large scene so may have to delete some stuff, will double check later.
Everytime I had problems with IES profiles was when a project was moved from a disk to another.
regards,
thats strange, i always use the project structure for everything, and for example i put like ies in data dir of the project structure and everything works ok, just make sure that the paths r not absolute…
cheers
