Randomisation melanin
Hi everybody!!! Happy New year,first!!! I have a problème with thé haïr matériel, when usinf “random mélanine” .. I was expecting for exemple somme darker haïr on clearer haïr, ans on fact, the result is that each SINGLE haïr bas horizontales stripes, liké a worm…Is it thé only possible result???
In fact, when I’m home, and can try different set up, the random melanin is not the problem… Well, I don’t undrerstand why some hairs are so striped! see doc joined, and tghank you for help, as it’s a problem on an assignment, and it’s panic!!!
I think it’s glint. Try to turn the parameter down.
As already mentioned, lowering the glint strength will help for close-ups. In my example the settings are:
Color:
Melanin= 6%
Random melanin= 20%
Reflection:
Glint strength= 0.02
I hope that helps.
thank you so much! effectively, the glint parameter was the killer!!!
