When I use Randomization on wood, the grain comes out at a certain angle or randomly in sections. The image is self explanatory. Am I doing something wrong?
Hi cajon49,
What you’ve shown is default behavior of the Randomizer.
You can however control the randomization parameters to avoid the texture rotation and use only an offset for example.
Here’s the default Stochastic randomization:
And here I’ve minimized the Rotation and slightly tweaked the Scale randomization values:
Hope that helps,
Konstantin
He had not had time to go through the forum carefully. I will check. Thanks for answering.
