Randomizer only on "U"
I would like to have randomness in these textures only in the “U”.
I can manually obtain the result, individually manipulating the tag of each object. But I would like to obtain an automatic randomization process only in the “U” Horizontality.
I tried to use UVW Randomizer, which works with two objects, but the problem is when I have 8 objects or more, the textures start to repeat themselves. To avoid this I had to do it manually in the offset of each material.
Hey, Francisco,
Thank you for the report. Could you please test the attached test and workflow?
Cheers
node_uvw_randomizer_instace.c4d (677 KB)
Hi boyan,
Thanks for the quick reply.
I did teste your fie using my texture (because yours was missing).
But the result is not want I would like to have.
Please notice that the main point is to randomize only on “U” Horizontally.
I achieved that result but manually on each tag offset.
The image attached on the message about is the result I want.
How can I do that with UVW randomizer?
Many thanks
Hey, Francisco,
Thank you for the responses. I believe that using UVW randomization in combination with other methods can achieve these results, and possibly even better outcomes. Please check the attached file.
Cheers,
uvw_randomizer.zip (454 KB)
Thanks Boyan this looks great.
Could you tell me please in this case what the UVW Transformer is doing?
Cheers
