I regularly need to make photo insertions, so I would need to display this totally raw picture without tonemapping or LUT, I tried the CoronaToneMappingControl but it does not really work and causes uncertain results. Is it possible to integrate in the corona VFB a display option of a raw background image?
It is not possible currently.
The ToneMapControl map should work for you, but it won’t work with some LUTs (there is a warning about this in this map’s settings). Also keep in mind that you need to restart your rendering after doing the tone mapping adjustments for the ToneMapControl to “refresh”.
