I just noticed that my raw reflection render element is somehow multiplied by my blend material masks. I.e it is already masked and looks like a reflection element but not complete with the reflection filter.
Should the raw reflection not be just that and the full reflection mask be contained in the reflection filter element?
If your mask is black in some places, V-Ray will naturally not compute any reflections there, so there is nothing to go into the raw element.
Further on, I would recommend to not use any of the raw passes that come out of V-Ray directly (except for informational purposes perhaps); instead, derive them in your compositing app using the other passes (i.e. raw reflection=reflection/reflection_filter).
There are some math inaccuracies in them at the minute so raw reflection by reflection filter won’t equal what is in the final render. I think Vlado mentioned that he’s correcting the internal calculations in vray to use the method he’s mentioned above.
Humh… well if vray RAW math is off and Photoshop is absolutely worthless at doing math in 32/16 bits then the only option left I have is nuke. Which mean that my workflow will get so much longer with RAW passes now Uhhh
But you’ll get a warm tingly feeling inside with all the great features that make your life easier.
As your elements are named by default you can more or less just swap your input file and then you’re onto the artistic stuff.
That’s just saved me a lot of time from re-jigging all my comps to not include RAW passes. I think I’ll just wait for Vray 3 and stick to using the RAW passes. Great work!
