Hey, am experimenting with the ‘Ray switcher texmap’ and seem to be having some problems.
Attached is a simple render of a sphere with corona sky in the GI slot, and a 360 panorama as the reflection slot. Pretty sure its not supposed to look like that.
Hey thanks for the reply, i could use the environment overrides yes but should the ray switcher not act in the same way when used in the environment slot?
Hey, since CoronaRaySwitch texmap doesn’t has hes own texture coordinates and you didn’t assigned any map to refract and direct slots, you should expect unexpected results when assign it as enviroment :] But this is just my guess. It could be a bug as well.
hi,
it is basically as Maru said. Rayswitch mtl is not intended to work in environment slot just because there are already override controls present in the render settings UI - it would clash if both sets of override worked.
